Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Weird radio issue (brain teaser)
    May 2017
    Default Weird radio issue (brain teaser)
    I have a 4 cylinder injected manual 1993 Magna wagon with a very weird radio issue. AM and FM both work fine when the engine is NOT running with the ignition switch in either the "Acc" and "On" positions. However as soon as the engine starts, the FM stops working but the AM still works fine. I assume it is something with the alternator or ignition system. What else could it be? Any ideas?
    Thanks
    John
    mcs_xi's Avatar
    Nov 2006
    Quote Originally Posted by johnb007 View Post
    Thanks
    John
    the radio internals are stuffed. They age and die.
    Current Ride D3 Audi A8 4.2 V8 Quattro Sport
    Current Ride 2004 KL Verada AWD
    Previous 3rd Gen's
    TE Magna Advance
    TF Magna Sports
    KH Verada XI
    TJ Magna S2 Advance
    TJ Magna VRX LE Sable
    TL Magna VR LE
    KL Verada AWD Leather Pack
    May 2017
    Update. I took alternator belt off, started the engine and FM is then working fine. So it is the alternator. No Alt warning light is on the dash and it is charging the battery no trouble. So it is some type of electrical noise suppression component attached to the alternator that has failed. Somehow it is cutting out the FM signal to the radio. Any ideas what that could be? I do not want to replace the alternator as it is working fine except that it cuts out the FM radio signal.
    magna buff's Avatar
    Default keep trying
    on a 4 cyl alternator shell there might be that little black box held on with a screw
    May 2017
    Quote Originally Posted by mcs_xi View Post
    Radio works fine with engine off (AM and FM). It turns out it is some weird thing associated with the alternator when it is running. Weird. Or I guess it could be some radio component that stops the alternator charging circuit from interfering with the FM circuit.
    magna buff's Avatar
    Default can you small box top left in picture
    little black box held on with one screw
    May 2017
    Before I figured out it was the alternator I did change the voltage regulator on the ignition system (284K00707) which of course made no difference. So it is either in the alternator circuit or in the radio circuit which shields the FM signal from the alternator interference. With the alternator not running the FM is strong and clear, but with the alternator running it is zero, not even much static.
    May 2017
    Quote Originally Posted by magna buff View Post
    I can see the regulator on the face of the alternator. Is that what you mean? I will go check the voltage that the alternator is putting out.
    magna buff's Avatar
    nope ..rectangle box top left on alt body ..may be a suppressor
    May 2017
    Voltage at battery terminals with engine off 12.7V and 14.4V with engine on. Maybe it is some circuit in the radio that shields the FM signal from electrical interference or maybe the FM circuit has become ultra sensitive to voltage variations so when it is 12.7V it is fine but when the voltage gets up to 14.4V the FM circuit stops working? I will ask a friend who is into radios. He might know.
